メインコンテンツにスキップ
Sony Betamovie BMC-220 Power Button Replacement
必要な工具と部品
  1. Sony Betamovie BMC-220 Power Button Replacement, Battery: 手順 1、 3の画像 1 Sony Betamovie BMC-220 Power Button Replacement, Battery: 手順 1、 3の画像 2 Sony Betamovie BMC-220 Power Button Replacement, Battery: 手順 1、 3の画像 3
    • Orient your Betamovie so that the back of the device is sitting flat, and the bottom of the device is facing you.
    • Slide the RELEASE switch up to bring the hand drip down.
  2. Sony Betamovie BMC-220 Power Button Replacement: 手順 2、 3の画像 1 Sony Betamovie BMC-220 Power Button Replacement: 手順 2、 3の画像 2 Sony Betamovie BMC-220 Power Button Replacement: 手順 2、 3の画像 3
    • Turn the BATTERY knob to OPEN, and open the lid.
    • Reminder: When inserting a new battery, make sure the knob is turned to OPEN.
    • Be careful not to point the hand grip down when turning the BATTERY knob. The battery pack may fall out.
  3. Sony Betamovie BMC-220 Power Button Replacement: 手順 3、 1の画像 1
    • Remove the battery from the Betamovie.
  4. Sony Betamovie BMC-220 Power Button Replacement, Power Button: 手順 4、 3の画像 1 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 手順 4、 3の画像 2 Sony Betamovie BMC-220 Power Button Replacement, Power Button: 手順 4、 3の画像 3
    • Remove the two screws (2mm x 6mm) on either side of the FILTER switch on the black and white side of the Betamovie using the Phillips #0 screwdriver.
    • Remove the two screws on the bottom of the camera on the side with the black and white face using the same screwdriver.
    • Remove the screws on the bottom of the back of the camera with the same screwdriver.
  5. Sony Betamovie BMC-220 Power Button Replacement: 手順 5、 2の画像 1 Sony Betamovie BMC-220 Power Button Replacement: 手順 5、 2の画像 2
    • Remove the silver rectangular piece at the top of the Betamovie using your hands.
    • Remove the two screws (2mm x 6mm) under the flat silver piece using the Phillips #1 screwdriver. The silver metal clip comes off once the crews are removed.
  6. Sony Betamovie BMC-220 Power Button Replacement: 手順 6、 3の画像 1 Sony Betamovie BMC-220 Power Button Replacement: 手順 6、 3の画像 2 Sony Betamovie BMC-220 Power Button Replacement: 手順 6、 3の画像 3
    • Remove the black and white cover from the Betamovie.
    • Remove the power button from the black and white face.
終わりに
作成者
3人の作成者と共同で作成されました。
Jordan Bates
メンバー登録日: 09/10/18
315 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team S2-G5, Bedsole Fall 2018 University of Alabama, Team S2-G5, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S2G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 11
今までの合計 565
