必要な工具と部品
Using the plastic opening tool, open one of the tabs on the bottom of the device.
While keeping the tab open, insert a opening pick in between the opening tool and tab.
Repeat this for the 3 other tabs.
Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
Using the same screwdriver, remove the three 9mm screws from the back of the device.
Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
ある他の人がこのガイドを完成しました。
