はじめに
The motherboard is the brain of the Sony BDP-S3700. This guide shows how to replace a faulty one.
必要な工具と部品
Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
Flip the Blu-ray back up
Remove the three ribbon cables that connect the disc drive to the motherboard.
Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
2 の人々がこのガイドを完成させました。
2 件のコメント
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
Same problem here.
