メインコンテンツにスキップ
Sony BDP-S1 Fan Replacement
必要な工具と部品
  1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: 手順 1、 2の画像 1 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: 手順 1、 2の画像 2
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1 Fan Replacement: 手順 2、 3の画像 1 Sony BDP-S1 Fan Replacement: 手順 2、 3の画像 2 Sony BDP-S1 Fan Replacement: 手順 2、 3の画像 3
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1 Fan Replacement: 手順 3、 3の画像 1 Sony BDP-S1 Fan Replacement: 手順 3、 3の画像 2 Sony BDP-S1 Fan Replacement: 手順 3、 3の画像 3
    • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1 Fan Replacement: 手順 4、 3の画像 1 Sony BDP-S1 Fan Replacement: 手順 4、 3の画像 2 Sony BDP-S1 Fan Replacement: 手順 4、 3の画像 3
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
  5. Sony BDP-S1 Fan Replacement, Fan: 手順 5、 3の画像 1 Sony BDP-S1 Fan Replacement, Fan: 手順 5、 3の画像 2 Sony BDP-S1 Fan Replacement, Fan: 手順 5、 3の画像 3
    • First we need to unscrew the fan from before we can remove it.
    • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
    • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
    • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
  6. Sony BDP-S1 Fan Replacement: 手順 6、 3の画像 1 Sony BDP-S1 Fan Replacement: 手順 6、 3の画像 2 Sony BDP-S1 Fan Replacement: 手順 6、 3の画像 3
    • We will now completely remove the fan from the player.
    • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
    • You are now ready to install the new fan!
終わりに
作成者
1人の作成者と共同作成されました。
Nicolas Kennedy
メンバー登録日: 01/26/14
111 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-30, Maness Winter 2014 Cal Poly, Team 9-30, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G30
3 メンバー
5のガイドは作成済み
2 件のコメント
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - 返信
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 2,417
