はじめに
In the situation that your Sony BDP-BX510 disk tray is not opening despite trying the solutions on the troubleshooting page, you may need to replace it . This guide will provide you with the steps required to safely remove your disk tray for replacement. The tools that are needed include a Phillips #2 screwdriver and tweezers.
必要な工具と部品
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
Pull the medium-sized 9 pin ribbon cable and the small 5 pin ribbon cable out of their connector in the motherboard.
Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
Pull the large 45 pin ribbon cable out of the connector in the motherboard.
