メインコンテンツにスキップ
Sony Alpha SLT-A55V Motherboard Replacement
必要な工具と部品
  1. Sony Alpha SLT-A55V Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Start by removing the focusing knob on the back of the camera.
  2. Sony Alpha SLT-A55V Motherboard Replacement: 手順 2、 1の画像 1
    • Remove all the screws on the bottom of the camera. There are two screws that can not be directly seen in this photo. These screws are shown in blue. One screw is hidden by the battery cap and the other is hidden by the battery recess.
  3. Sony Alpha SLT-A55V Motherboard Replacement: 手順 3、 1の画像 1
    • Remove three screws from the right side of the camera.
  4. Sony Alpha SLT-A55V Motherboard Replacement: 手順 4、 1の画像 1
    • While you are on the left side of the camera, lift the HDMI / USB cover and remove the two screws that are hidden.
  5. Sony Alpha SLT-A55V Motherboard Replacement: 手順 5、 1の画像 1
    • On the top of the camera there is a black plastic sticker that hides two screws which must be removed.
    • This sticker can be re-used. Peel the sticker off and place it on a clean piece of parchment paper or wax paper. This will prevent dirt and dust from getting on the adhesive.
    • Remove the two screws that lie beneath the sticker. The arrows indicate the location of these screws.
  6. Sony Alpha SLT-A55V Motherboard Replacement: 手順 6、 1の画像 1
    • Remove two screws from the left hand side of the camera.
  7. Sony Alpha SLT-A55V Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the two screws immediately below the flash. These screws are located on the face of the camera.
  8. Sony Alpha SLT-A55V Motherboard Replacement: 手順 8、 1の画像 1
    • All the necessary screws are removed. Begin prying the back away from the camera in order to remove the front cover.
  9. Sony Alpha SLT-A55V Motherboard Replacement: 手順 9、 1の画像 1
    • Pry open the enclosure carefully. The ribbon cables for the LCD are located on the right side and will need to be disconnected from the motherboard before removing the back of the case.
  10. Sony Alpha SLT-A55V Motherboard Replacement: 手順 10、 1の画像 1
    • Some of the ribbon cables are held in with minature clips. These cables can be identified by the side hinge that can be released with a pointed end.
  11. Sony Alpha SLT-A55V Motherboard Replacement: 手順 11、 1の画像 1
    • Once the back of the camera is removed the motherboard is exposed.
    • Remove all ribbon cables that are connected to the motherboard. There are two ribbon cables that are stacked the location marked in blue. One cable is is connected under the board while the other is connected to the top.
  12. Sony Alpha SLT-A55V Motherboard Replacement: 手順 12、 1の画像 1
    • Remove four screws to release the motherboard from the camera.
  13. Sony Alpha SLT-A55V Motherboard Replacement: 手順 13、 1の画像 1
    • Carefully remove the motherboard , this may take delicate tools in order to prevent damage to the underlying electronics.
  14. Sony Alpha SLT-A55V Motherboard Replacement: 手順 14、 1の画像 1
    • Once the motherboard has been completely unplugged and removed, it can be replaced and reassembled in reverse order.
終わりに
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sultan Almunif
メンバー登録日: 09/26/15
357 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-1, Wilson Fall 2015 IUPUI, Team 1-1, Wilson Fall 2015人のメンバー
IUPUI-WILSON-F15S1G1
4 メンバー
6のガイドは作成済み
コメント 1 件
Hi Mr Almunif
I have a SONY ALPHA SLT A55V that stopped working.
Sony South Africa quoted ZAR 17, 000 to repair this camera when the latest model over here will cost me ZAR 25, 000
Sony indicated that the camera needs a new Main PC Board and a Shutter Charge Unit or Shutter Change unit. Not sure from their handwriting on the quote
I can buy a new PC on ebay but need to find a charge unit
Can you assist with this and also on how to replace it
My previous A55 was stolen and the one I have is much needed to take videos of the properties that I sell for clients. m in the real estate business in South Africa
Regards
Chris Breet
CHRIS BREET - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 36
今までの合計 3,830
