メインコンテンツにスキップ
Sony Alpha NEX-6 Lens-release Button Replacement
必要な工具と部品
  1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: 手順 1、 1の画像 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 手順 2、 2の画像 1 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: 手順 2、 2の画像 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: 手順 3、 1の画像 1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens-release Button Replacement: 手順 4、 3の画像 1 Sony Alpha NEX-6 Lens-release Button Replacement: 手順 4、 3の画像 2 Sony Alpha NEX-6 Lens-release Button Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens-release Button Replacement: 手順 5、 2の画像 1 Sony Alpha NEX-6 Lens-release Button Replacement: 手順 5、 2の画像 2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
  6. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: 手順 6、 1の画像 1
    この手順で使用する道具:
    購入する
    • By using tweezers, carefully remove the lens-release button by lifting upward.
終わりに
作成者
4人の作成者と共同で作成されました。
Clayton Dale
メンバー登録日: 01/20/15
1,067 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 11-2, Blackwell Winter 2015 USF Tampa, Team 11-2, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S11G2
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 20
今までの合計 1,250
