はじめに
A guide to show the replacement procedure of the motherboard.
必要な工具と部品
Hold the device with the lens facing you, and grasp the battery compartment.
Locate the split on the side of the battery compartment.
Locate the split and insert the prying tool.
Pull the prying tool towards the LCD screen to begin separating the split.
This forgot to mention the part you need to ALSO REMOVE THE SCREW next the the battery release knob.
Michael HO - 返信
Insert prying tool in the split between the top panel (where you find the movie button) and the LCD screen.
Jiggle the prying tool and pull the tool away from the device.
This forgot to mention the part you need to ALSO REMOVE THE SCREW on the flash light mount
Michael HO - 返信
To the right of where you unscrewed the copper screws, unscrew 4 black 1.2 mm Phillips #000 screws.
Pull off the metal back from the device body.
Locate a thin metal piece on top of the motherboard, and unscrew 4 silver 1.2 mm Phillips #000 screws in the corners of the metal piece.
Underneath. you will locate the motherboard.
The tripod piece will be loose. Take the piece from the device and set it off to the side.
Lift the gray plastic camera piece surrounding the motherboard up.
Leave the long, thin ribbon cable that runs along the gray piece attached. It is not necessary to detach.
Lift up the motherboard to reveal one final thin ribbon cable connected to a white retaining tab underneath the motherboard.
Flip up the white retaining tab, and utilize tweezers to pull out the final thin ribbon cable.
3 の人々がこのガイドを完成させました。
2 件のコメント
Thanks a lot friend.. My 5n don't star… some day the metal cortine closet after 1 minute I shot down the camera and never more star again..
I will try to fix it…
I live in Cuba and we no have technicians for this camera…
Best regard…
Ramon
The flip up retaining tabs on the ZIF ribbon connectors are black rather than white as stated. Just want to point that out in case someone attempts to pry up the wrong ends and damages them.
