必要な工具と部品
Right side, remove 1 M1.4x3.7 screw
Left side, remove 3 M1.4x3.7 screws
Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
Remove LCD hinge cover, by sliding to the left.
Remove back cover, actually just a plastic frame.
Loosen LCD assemble with caution!
Release FPC cable, the connector is flip type.
Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
Pop the grip off. From back, push to the right, then it flies forward.
Sensor power, flip
Sensor signal, flip
Shutter, pull
Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
Whatever, pull
Whatever, pull
Shutter charger motor FPC, (backside, pull out)
Remove 3 ST1.7x5 screws
Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
