メインコンテンツにスキップ
Sony Alpha DSLR- A850 Focus lens Replacement
必要な工具と部品
  1. Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 手順 1、 3の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 手順 1、 3の画像 2 Sony Alpha DSLR- A850 Focus lens Replacement, Focus lens: 手順 1、 3の画像 3
    • Push in the button next to the lens.
    • While holding the button twist the lens counter-clockwise.
    • Pull up and remove lens from camera.
  2. Sony Alpha DSLR- A850 Focus lens Replacement: 手順 2、 3の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 2、 3の画像 2 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 2、 3の画像 3
    • Inside toward the top you will find a small slit in the plastic piece.
    • Insert a flat head screw driver into the slit and pull down to access the focus lens.
  3. Sony Alpha DSLR- A850 Focus lens Replacement: 手順 3、 3の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 3、 3の画像 2 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 3、 3の画像 3
    • Using tweezers grab the focus lens on the side by the two tabs that are on it.
    • Do not grab the focus lens in the middle as this will damage the lens.
    • Pull out and remove focus lens from camera.
  4. Sony Alpha DSLR- A850 Focus lens Replacement: 手順 4、 3の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 4、 3の画像 2 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 4、 3の画像 3
    • When inserting new focus make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
    • Angle the focus lens to make installation easier.
    • Lay the new focus lens into the plastic tray.
    • It does not snap into place.
  5. Sony Alpha DSLR- A850 Focus lens Replacement: 手順 5、 2の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 5、 2の画像 2
    • Insert screw driver into the slit and push up to close.
    • You can also use your thumb, if you are careful not to touch the lens as this could leave a smudge on the lens.
    • You will hear a click when the plastic tray is back in place.
  6. Sony Alpha DSLR- A850 Focus lens Replacement: 手順 6、 2の画像 1 Sony Alpha DSLR- A850 Focus lens Replacement: 手順 6、 2の画像 2
    • When re-installing the lens line up the orange dots that are one both lens and camera.
    • Fit lens into place and turn clockwise to secure it back to camera.
終わりに
You have now completed a focus lens replacement.
作成者
1人の作成者と共同作成されました。
Walter Littlefield
メンバー登録日: 03/21/18
265 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team S2-G4, Kim Spring 2018 University of Memphis, Team S2-G4, Kim Spring 2018人のメンバー
UM-KIM-S18S2G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 741
