メインコンテンツにスキップ
Sony Alpha A350 : LCD Replacement
必要な工具と部品
  1. Sony Alpha A350 : LCD Replacement, LCD: 手順 1、 2の画像 1 Sony Alpha A350 : LCD Replacement, LCD: 手順 1、 2の画像 2
    • Lift up the screen.
    • Unscrew the two Phillips #000 screws on each side of the screen.
  2. Sony Alpha A350 : LCD Replacement: 手順 2、 2の画像 1 Sony Alpha A350 : LCD Replacement: 手順 2、 2の画像 2
    • Use a plastic spudger to gently pry open the screen.
    • Continue to push and slide along the edge of the screen.
  3. Sony Alpha A350 : LCD Replacement: 手順 3、 2の画像 1 Sony Alpha A350 : LCD Replacement: 手順 3、 2の画像 2
    • Lift up the glass screen protector from the LCD.
    • Lift the LCD to expose the ZIF connector.
  4. Sony Alpha A350 : LCD Replacement: 手順 4、 2の画像 1 Sony Alpha A350 : LCD Replacement: 手順 4、 2の画像 2
    • Identify the ZIF (zero insertion force)connector (the black bar).
    • Flip the lever up and pull the connector out (Be sure not to yank the connector out to avoid damage).
    • Connect the new LCD and then flip the lever down.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sydney Duncan
メンバー登録日: 10/10/16
772 ポイント
5のガイドは作成済み
チーム
CJLADIES CJLADIES人のメンバー
Community
1 メンバー
10のガイドは作成済み
11 件のコメント
This repair guide seems to show the replacement of a AUO Version of Sony Alpha A350 LCD Replacement. Could someone show how to replace a Sony version of a Sony Alpha A350 LCD Replacement. The two are different. Thanks
David - 返信
David,
if you're still looking to solve this : replacing the AUO version or the Sony version of the LCD is exactly the same. However, things get more complicated when you had a broken AUO and want to replace it with a SONY LCD, or vice versa, because the flex circuit (visible in step 4 ) is different between a AUO and SONY LCD. So without switching the flex circuit, you will not be able to switch the LCD from a Sony to a AUO or from a AUO to a Sony.
Am I making sense ? There are I think 4 versions in total of all flex circuits + components (according to the service manual) : 1 is unique for the AUO, 1 is for the Sony, and the last 1 is for both, but depending on components soldered onto it, it needs to be used for either AUO or Sony.
Switching to AUO makes sense, because prices for a Sony replacement LCD nowadays will cost you more then the complete camera.
AUO LCD's can be found for about 20 - 40 $ . If only you could get hold of the appropriate flex circuit.
Hope this helps.
Regards
lockinvar - 返信
years ago i had attempted to replace the screen with no knowledge and i broke the lever, my question to you is how do i fix it now?
Moriah Foster - 返信
Moriah, I have the same issue. did you solve it ? I have a replacement screen but the ZIF plastic connector is broken. Did you find a way to fix it ?
Leopoldo Bolanos -
This is BS. Thee is only one original screen, which is from Sony. AUO is an aftermarket screen, which isn’t suitable without a new flexcable. So if someone ask you which screen it is, if not replaced in the meantime, it’s always Sony.
R Dolphijn - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 86
今までの合計 8,291
