メインコンテンツにスキップ
Sony Alpha A3000 Built-in flash Replacement
必要な工具と部品
  1. Sony Alpha A3000 Built-in flash Replacement, Rear Case: 手順 1、 3の画像 1 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 手順 1、 3の画像 2 Sony Alpha A3000 Built-in flash Replacement, Rear Case: 手順 1、 3の画像 3
    • Remove the seven highlighted screws shown here.
    • Screws are teeny tiny, don't lose them!
  2. Sony Alpha A3000 Built-in flash Replacement: 手順 2、 2の画像 1 Sony Alpha A3000 Built-in flash Replacement: 手順 2、 2の画像 2
    • Remove this final screw from the memory card compartment.
    • Remove the chassis by pulling the back cover away from the camera.
    • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
  3. Sony Alpha A3000 Built-in flash Replacement: 手順 3、 2の画像 1 Sony Alpha A3000 Built-in flash Replacement: 手順 3、 2の画像 2
    • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
  4. Sony Alpha A3000 Built-in flash Replacement, Built-in flash: 手順 4、 1の画像 1
    • Remove the single screw from the bottom of the flash device.
  5. Sony Alpha A3000 Built-in flash Replacement: 手順 5、 1の画像 1
    • Remove the flash cover by gently pulling it in an outward direction.
  6. Sony Alpha A3000 Built-in flash Replacement: 手順 6、 1の画像 1
    • Use a soldering tool to remove the three wires connecting the flash to the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Leonard Holloman
メンバー登録日: 08/31/15
638 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 4-4, Meier Fall 2015 USF Tampa, Team 4-4, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G4
4 メンバー
10のガイドは作成済み
3 件のコメント
Thx, saved me from draing costs for cleaning my viewfinder from watercolor paint. also hotshoe adapter disassembly was easier than other parts. be careful, if you want to do it!
Michael Smith - 返信
My LCD and viewfinder are not working anymore. I think is the flex that broke up... or the socket where is connected... And there is no replacement pieces in my country.......... As well as it is not a cheap camera for us........ I want to kill myself.........................
l2weenlive - 返信
Any procedure for SONY a6300 built-in flash replacement?
Vivek Dhar - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 1,935
