メインコンテンツにスキップ
Sony Action Cam HDR-AS15 Speaker Removal
必要な工具と部品
  1. Sony Action Cam HDR-AS15 Speaker Removal, Sony Action Cam HDR-AS15 Speaker Removal: 手順 1、 2の画像 1 Sony Action Cam HDR-AS15 Speaker Removal, Sony Action Cam HDR-AS15 Speaker Removal: 手順 1、 2の画像 2
    • Remove battery. Open bottom hatch. Remove the 2x screws with mini philips driver, the bottom hatch door should just come out with a little pull now.
  2. Sony Action Cam HDR-AS15 Speaker Removal: 手順 2、 2の画像 1 Sony Action Cam HDR-AS15 Speaker Removal: 手順 2、 2の画像 2
    • Gently press the tab in the center as you slide out the electronics.
  3. Sony Action Cam HDR-AS15 Speaker Removal: 手順 3、 2の画像 1 Sony Action Cam HDR-AS15 Speaker Removal: 手順 3、 2の画像 2
    • Remove 2x screws over the metal retaining clip; one is above the LCD and one is below. Gently pull the plastic tab at the top as you swing the metal retaining clip downward. Desolder the speaker. Replace the metal retaining clip and 2x screws.
  4. Sony Action Cam HDR-AS15 Speaker Removal: 手順 4、 1の画像 1
    • Slide electronics back into the housing. Replace bottom port cover and 2x screws. Replace battery. Cut tether to the bottom hatch, replace on bottom of camera.
終わりに
Enjoy silent operation and hassle-free access to the ports!
Even Easier: you can skip some steps if you just clip one of the wires to the speaker (red or blue), and leave the speaker in the unit.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
joseph
メンバー登録日: 05/16/13
136 ポイント
1ガイドが承認済み
5 件のコメント
Nice. Now how about making it easier to attach a remote microphone? One should be able to pull out or connect a pigtail to the 3mm jack and make a dongle outside the case, no? :)
flyrv9 - 返信
The other way is to turn off the sound through the setup menu….
edward - 返信
I came here to say what edward said :P
Although you have to upgrade the firmware first, I think...
ahahah -
Wow, good pics. Seems you don't even need the (dis-)assembly guide I just found: http://elektrotanya.com/sony_hdr-as15_le...
:-D
wwwaste - 返信
Where can I find sony action cam parts, I need some for the bottom of this cam....ANY LINKS OR SITES...Thank U
usbreaks - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 18
今までの合計 3,013
