はじめに
Are the videos in your device corrupted? Maybe you need more space for your spectacular videos? Here is a simple guide on how to remove or replace a memory card in the Sony HDR-AS15.
To access the memory card, push left on the rear of the Action Cam. The rear panel should easily slide to the side.
After sliding the rear panel to the side, open the door outward to reveal the memory card slot and battery tray.
Push in on the back of the memory card with the tip of your finger until you feel a click.
Pinch the rear of the memory card that is protruding from the slot and pull on it until the memory card is removed.
