はじめに
Sometimes batteries die. In this guide, we will show you how to replace the battery in the Sony Action Cam HDR-AS15. This is a relatively simple guide, not requiring the removal of any screws.
ツール
パーツ
パーツは指定されていません。
To access the battery, push left on the rear cover of the action cam. The rear panel should easily slide to the side.
Open the rear panel outward to reveal the battery tray and memory card slot.
Pinch the protruding bar next to the "Pull" text and slide the tray outwards.
When the battery tray has been removed from the Action Cam, you can simply pull the battery out of the tray.
ある他の人がこのガイドを完成しました。
