メインコンテンツにスキップ
Sony α6000 LCD Screen Replacement
必要な工具と部品
  1. Sony α6000 LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Remove the two 1.75mm Phillips #00 screws located on the bottom border of the LCD screen.
  2. Sony α6000 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the two 1.75mm Phillips #00 screws located on the back side of the LCD screen.
  3. Sony α6000 LCD Screen Replacement: 手順 3、 1の画像 1
    • Carefully separate the bottom border of the frame from the back surface of the LCD screen.
  4. Sony α6000 LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the silver shield from the back side of the LCD screen.
  5. Sony α6000 LCD Screen Replacement: 手順 5、 1の画像 1
    • Remove the smaller bracket covering the bottom portion of the control board.
  6. Sony α6000 LCD Screen Replacement: 手順 6、 1の画像 1
    • Carefully remove the spacer from behind the LCD screen.
  7. Sony α6000 LCD Screen Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    • Detach the ribbon from the socket with a pair of tweezers.
  8. Sony α6000 LCD Screen Replacement: 手順 8、 1の画像 1
    • Pull the LCD screen away from the camera and set aside.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Rohn Albertson
メンバー登録日: 07/14/19
635 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G2, Harley Summer 2019 IUPUI, Team S2-G2, Harley Summer 2019人のメンバー
IUPUI-HARLEY-SU19S2G2
3 メンバー
6のガイドは作成済み
2 件のコメント
Step 2 makes this repair impossible, the LCD screen is stuck at an angle where it's impossible to get a normal Phillips onto it without stripping the screw. Horribly inaccurate picture of how 'easy' it is to put the screwdriver there. Don't follow this guide.
Rawr Peng - 返信
Saw a bran new a6000 screen on eBay. So, I thought it would be easy to replace the scratched screen from my a6000. WOW was I wrong!
First I would say that step 2 is very hard to accomplish without stripping the screw. You need to pry the screen to get to an angle where it's doable. On my first attempt I striped the screw. I tried it on a second a6000 and successfully could remove the screw.
As it wasn't evident to me at first, I think it's important to specify that on step 7 you need to lift carefully the little black flap on the zero insertion force cable connector to unlock it. It's weak and I feel like it would be very prone to breaking.
What is NOT showed on this guide is what comes AFTER step 8! The screen is actually in a plastic frame That does not ship with the replacement screen and this frame is glued! So unless you have plastic glue and are able to unglue it first, you should NOT attempt this repair.
Consequently, I reassembled everything and have resigned myself to living with the scratchs.
Drgonz0 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 124
今までの合計 6,300
