メインコンテンツにスキップ
Sony α6000 Back Case Replacement
必要な工具と部品
  1. Sony α6000 Back Case Replacement, Battery: 手順 1、 2の画像 1 Sony α6000 Back Case Replacement, Battery: 手順 1、 2の画像 2
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Back Case Replacement: 手順 2、 2の画像 1 Sony α6000 Back Case Replacement: 手順 2、 2の画像 2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Back Case Replacement: 手順 3、 2の画像 1 Sony α6000 Back Case Replacement: 手順 3、 2の画像 2
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Back Case Replacement: 手順 4、 2の画像 1 Sony α6000 Back Case Replacement: 手順 4、 2の画像 2
    • Remove the battery.
  5. Sony α6000 Back Case Replacement, Back Case: 手順 5、 1の画像 1
    • Position the camera with the bottom facing upwards and the lens facing away from you.
  6. Sony α6000 Back Case Replacement: 手順 6、 1の画像 1
    • Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
  7. Sony α6000 Back Case Replacement: 手順 7、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
    • There may be screws on either side by the camera strap mounts. If removing the screw on the left side doesn't sufficiently loosen the case, be sure to check for a screw on the other side before resorting to excessive force.
  8. Sony α6000 Back Case Replacement: 手順 8、 2の画像 1 Sony α6000 Back Case Replacement: 手順 8、 2の画像 2
    • Position the camera with the battery housing facing upwards.
    • Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
  9. Sony α6000 Back Case Replacement: 手順 9、 1の画像 1
    • Position the camera with the flash assembly facing upwards.
    • Remove the screw located underneath with a Phillips #00 screwdriver.
  10. Sony α6000 Back Case Replacement: 手順 10、 2の画像 1 Sony α6000 Back Case Replacement: 手順 10、 2の画像 2
    • Pull back the LCD screen.
    • Remove the three screws directly underneath using the Phillips #00 screwdriver.
  11. Sony α6000 Back Case Replacement: 手順 11、 1の画像 1
    • Gently pop off the top case of the camera using your fingers or a plastic opening tool.
    • If using a plastic opening tool, ensure that the pressure is being applied to the plastic rather than the metal.
  12. Sony α6000 Back Case Replacement: 手順 12、 2の画像 1 Sony α6000 Back Case Replacement: 手順 12、 2の画像 2
    • Position the camera with the LCD screen facing upwards.
    • Gently remove the back case guiding it around the LCD screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ryan Bilitski
メンバー登録日: 10/02/19
199 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 70
今までの合計 1,587
