はじめに
If the bass in your Sonos Playbase is weak or distorted, the subwoofer may be failing or non-functional. This guide shows you how to remove and replace the subwoofer.
必要な工具と部品
この手順で使用する道具:Pro Tech Toolkit$79.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
ある他の人がこのガイドを完成しました。
