この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Caution: Unplug the Sonos Playbase before starting the disassembly to avoid electrocuting yourself.
Replacement of a main speaker requires iFixit prying tools and screwdrivers. Optionally, a heat source helps to more easily remove adhesive while opening up your device.
必要な工具と部品
この手順で使用する道具:Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
