メインコンテンツにスキップ
はじめに
Caution: Unplug the Sonos Playbase before starting the disassembly to avoid electrocuting yourself.
Replacement of a main speaker requires iFixit prying tools and screwdrivers. Optionally, a heat source helps to more easily remove adhesive while opening up your device.
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  1. Disconnect the main speaker array from the  main board, by pinching and and pulling the tab out. See  Recognizing & Disconnecting Cable Connectors for more information.
  2. Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling  out the connector. See  Recognizing & Disconnecting Cable Connectors for more information.
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  3. Remove the main speaker array by gripping it on both sides and pulling it out.
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  4. Prop the removed main speaker array up on top of the main circuit board.
    • Prop the removed main speaker array up on top of the main circuit board.
終わりに
James Andrews
メンバー登録日: 2018年10月08日
421 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018人のメンバー
CPSU-WHITE-F18S17G2
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 27
