メインコンテンツにスキップ
Sonos Connect Bottom Motherboard Replacement
必要な工具と部品
  1. Sonos Connect Bottom Motherboard Replacement, WIFI Card: 手順 1、 3の画像 1 Sonos Connect Bottom Motherboard Replacement, WIFI Card: 手順 1、 3の画像 2 Sonos Connect Bottom Motherboard Replacement, WIFI Card: 手順 1、 3の画像 3
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect Bottom Motherboard Replacement: 手順 2、 3の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 2、 3の画像 2 Sonos Connect Bottom Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect Bottom Motherboard Replacement: 手順 3、 3の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 3、 3の画像 2 Sonos Connect Bottom Motherboard Replacement: 手順 3、 3の画像 3
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect Bottom Motherboard Replacement: 手順 4、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 4、 2の画像 2
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect Bottom Motherboard Replacement: 手順 5、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 5、 2の画像 2
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect Bottom Motherboard Replacement: 手順 6、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect Bottom Motherboard Replacement: 手順 7、 3の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 7、 3の画像 2 Sonos Connect Bottom Motherboard Replacement: 手順 7、 3の画像 3
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Sonos Connect Bottom Motherboard Replacement, Top Motherboard: 手順 8、 1の画像 1
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Sonos Connect Bottom Motherboard Replacement: 手順 9、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 9、 2の画像 2
    • Flip the board over to access the Molex Cable.
  10. Sonos Connect Bottom Motherboard Replacement: 手順 10、 1の画像 1
    • Disconnect the Molex Cable from the top motherboard.
  11. Sonos Connect Bottom Motherboard Replacement, Internal Power Supply: 手順 11、 2の画像 1 Sonos Connect Bottom Motherboard Replacement, Internal Power Supply: 手順 11、 2の画像 2
    • Remove foam protective insulator from the bottom board.
  12. Sonos Connect Bottom Motherboard Replacement: 手順 12、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 12、 2の画像 2
    • Picture shows the side of the device.
    • Remove the 7mm length Phillips screw from the power supply motherboard.
  13. Sonos Connect Bottom Motherboard Replacement: 手順 13、 3の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 13、 3の画像 2 Sonos Connect Bottom Motherboard Replacement: 手順 13、 3の画像 3
    • Remove the adhesive backed rear label by using a spudger.
    • Remove the two 8mm length screws as shown.
  14. Sonos Connect Bottom Motherboard Replacement: 手順 14、 2の画像 1 Sonos Connect Bottom Motherboard Replacement: 手順 14、 2の画像 2
    • Pull the power supply out of the back of the device.
  15. Sonos Connect Bottom Motherboard Replacement, Bottom Motherboard: 手順 15、 2の画像 1 Sonos Connect Bottom Motherboard Replacement, Bottom Motherboard: 手順 15、 2の画像 2
    • Remove the two 7.5mm length screws on the top of the board.
  16. Sonos Connect Bottom Motherboard Replacement: 手順 16、 1の画像 1
    • Remove the other two 8mm length screws on the back of the device. You might have already removed the screws for the power supply, and that's OK!
  17. Sonos Connect Bottom Motherboard Replacement: 手順 17、 1の画像 1
    • Slide the board out from the plastic casing.
    • You must pull the board out from back to front, because of the plugs on the back of the board.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Clark Snyder
メンバー登録日: 01/21/16
483 ポイント
4のガイドは作成済み
チーム
IUPUI, Team 3-2, Baechle Spring 2016 IUPUI, Team 3-2, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S3G2
4 メンバー
4のガイドは作成済み
コメント 1 件
I have bad audio on one channel, who supplies parts for this equipment?
Luis Nunes - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 45
今までの合計 6,118
