メインコンテンツにスキップ
Sol Republic Deck Volume Buttons Replacement
必要な工具と部品
  1. Sol Republic Deck Volume Buttons Replacement, Volume Buttons: 手順 1、 2の画像 1 Sol Republic Deck Volume Buttons Replacement, Volume Buttons: 手順 1、 2の画像 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • To separate the front face plate from the bottom half of the speaker, insert a spudger into the the middle groove.
    • Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck Volume Buttons Replacement: 手順 2、 2の画像 1 Sol Republic Deck Volume Buttons Replacement: 手順 2、 2の画像 2
    • Locate the black plastic volume buttons on each side of the back of the speaker face.
    • A piece of black tape on the side panel may also be covering the yellow connector tip that holds the volume button in place. Remove the black tape if necessary.
  3. Sol Republic Deck Volume Buttons Replacement: 手順 3、 1の画像 1
    • Using the plastic spudger, pry the button from the front plate of the speaker. The volume button is connected to the speaker by a plastic tab that has blue glue holding it down. The entire volume button can be removed from the front plate by carefully using the spudger to lift it up until it comes off.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Rebekah Simmons
メンバー登録日: 09/24/15
221 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-1, Sydow campbell Fall 2015 University of Alabama, Team 1-1, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G1
5 メンバー
3のガイドは作成済み
3 件のコメント
Thanks for the help
Rebecca Parrish - 返信
No problem! Glad you were able to fix your speaker :)
Shelby Ray -
So I dropped my speaker from 2 ft and the volume up doesn't work even after opening it up and trying to replace it. Is there any thing I may have missed?
nick ed - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 1,165
