メインコンテンツにスキップ
Sol Republic Deck LED Lights Replacement
必要な工具と部品
  1. Sol Republic Deck LED Lights Replacement, LED Lights: 手順 1、 2の画像 1 Sol Republic Deck LED Lights Replacement, LED Lights: 手順 1、 2の画像 2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Insert the tip of a plastic opening tool or spudger into the the middle groove along the edge of the device.
    • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck LED Lights Replacement: 手順 2、 2の画像 1 Sol Republic Deck LED Lights Replacement: 手順 2、 2の画像 2
    • Using a PH00 screwbit, unscrew the two three-tenth cm screws and remove them.
    • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
  3. Sol Republic Deck LED Lights Replacement: 手順 3、 1の画像 1
    • Using a PH00 screwbit, unscrew the two three-tenth screws that hold down the LED light strip at both ends.
  4. Sol Republic Deck LED Lights Replacement: 手順 4、 1の画像 1
    • Using a PH00 screw bit, unscrew the three screws that hold down the motherboard.
  5. Sol Republic Deck LED Lights Replacement: 手順 5、 1の画像 1
    • Use tweezers and fingers to lift tab and ZIF (zero insertion force) connecter.
  6. Sol Republic Deck LED Lights Replacement: 手順 6、 1の画像 1
    • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
  7. Sol Republic Deck LED Lights Replacement: 手順 7、 1の画像 1
    • If you pull the LED light plate too hard, then the motherboard will snap in half.
    • Lift the LED light plate attached to the motherboard off.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Kristina Patel
メンバー登録日: 09/24/15
137 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-1, Sydow campbell Fall 2015 University of Alabama, Team 1-1, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G1
5 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 2,006
