はじめに
This guide will walk you through the process of replacing your broken, dead, or dying battery in your Motorola X Sol Republic Deck.
必要な工具と部品
With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
Remove ribbon cable from the circuit board.
My ribbon is broken what to do where will be this I get 😭 my brain is not working please ifixit tell me where I get this
Rehan Khan - 返信
Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
Melt the solder with an iron and used the tweezers to pull the wire upright.
You can pull the circuit board up and away from the wires once the wires are pointed up.
Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
Remove the battery from the battery case.
Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
4 の人々がこのガイドを完成させました。
10 件のコメント
What type of battery is it?
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - 返信
The wires which are blue and purple are connected to battery body if im not wrong
Sounds was not clayer and battery is ded
My solo deck is not good sound was not well and battery is not charge
My deck is not responding for charging and not getting switch on all in sudden.
Any suggestions please.
