メインコンテンツにスキップ
Sol Republic Deck Battery Replacement
必要な工具と部品
  1. Sol Republic Deck Battery Replacement, Battery: 手順 1、 1の画像 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: 手順 2、 1の画像 1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: 手順 3、 1の画像 1
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: 手順 4、 2の画像 1 Sol Republic Deck Battery Replacement: 手順 4、 2の画像 2
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: 手順 5、 1の画像 1
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: 手順 6、 3の画像 1 Sol Republic Deck Battery Replacement: 手順 6、 3の画像 2 Sol Republic Deck Battery Replacement: 手順 6、 3の画像 3
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ross Bolton
メンバー登録日: 03/21/17
133 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017人のメンバー
IUPUI-BAECHLE-S17S3G1
3 メンバー
3のガイドは作成済み
10 件のコメント
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - 返信
What type of battery is it?
Peter Perez - 返信
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - 返信
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 53
今までの合計 7,844
