メインコンテンツにスキップ
SodaStream Fountain Jet A200 CO2 Tube Replacement
  1. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: 手順 1、 2の画像 1 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the front cover: 手順 1、 2の画像 2
    • Locate the two prongs at the bottom of the button which releases the bottles (at the front of the machine).
    • Push both prongs down together; pull this part of the machine out towards you.
  2. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: 手順 2、 2の画像 1 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the back cover: 手順 2、 2の画像 2
    • Press in the two gray oval shaped buttons found on either side.
    • Gently pull back on the cover until it releases from the device.
    • Release the buttons and pull the back completely off.
  3. SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: 手順 3、 2の画像 1 SodaStream Fountain Jet A200 CO2 Tube Replacement, Removing the Carbonation button: 手順 3、 2の画像 2
    • Place your hand under the carbonation button and pull up and away from you, towards the back of the machine.
    • Warning: be careful not to pull too hard on the carbonation button; there is a spring under this button that can become loose.
  4. SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: 手順 4、 2の画像 1 SodaStream Fountain Jet A200 CO2 Tube Replacement, Tightening caps on tubes: 手順 4、 2の画像 2
    • Under the carbonation button, at the end of the slim black tube will be a white cap, turn the cap in a counter clock wise motion to remove.
    • Locate the second white cap, on the front of the machine. Reattach both white caps by turning them in a clockwise direction, ensuring they are on tight.
  5. SodaStream Fountain Jet A200 CO2 Tube Replacement, Putting machine back together: 手順 5、 1の画像 1
    • Line up the prongs on the front cover with those on the machine and gently push until in place.
終わりに
8 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Katie Fetters
メンバー登録日: 09/17/14
815 ポイント
4のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-2, Mathis Fall 2014 University of Kentucky Louisville, Team 1-2, Mathis Fall 2014人のメンバー
LOUISVILLE-MATHIS-F14S1G2
3 メンバー
7のガイドは作成済み
8 件のコメント
Where do you find that black tube with the white caps on the internet. My white cap broke and can't find the replacement part.
Craig V - 返信
mine broke too. plastic nut split in half. probably from chill of CO2 expansion.
where to get replacement part?
brockybeek - 返信
I’m trying to find this nut and tube everywhere. any idea where we can purcase it? or the size and pitch of the nuts au tube?
Michel Bastien - 返信
that makes four of us— where’s the tubing available??
jess youngquest - 返信
Sodastream refuses to sell parts. Maybe get a non working one on eBay for parts.
jimmylasvegas - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 114
今までの合計 15,819
