はじめに
In this guide, the reader will learn how to properly remove an empty CO2 tank and replace it with a new full tank.
必要な工具と部品
Remove the back cover of the device. Press in the two gray buttons found on either side, located at the top of the machine.
Pull back on the cover until it releases from the device. Pull the back completely off.
Insert the full CO2 tank up through the hole, located at the bottom of the device.
Line up the new CO2 tank with the valve at the top and twist the tank in, using a counter clockwise motion.
ある他の人がこのガイドを完成しました。
