メインコンテンツにスキップ
Snapfon ezOne Speaker Replacement
必要な工具と部品
  1. Snapfon ezOne Speaker Replacement, Remove the battery cover: 手順 1、 1の画像 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ezOne Speaker Replacement, Remove the battery: 手順 2、 1の画像 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ezOne Speaker Replacement, Removing the plastic inserts: 手順 3、 2の画像 1 Snapfon ezOne Speaker Replacement, Removing the plastic inserts: 手順 3、 2の画像 2
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ezOne Speaker Replacement, Remove the shield screws: 手順 4、 3の画像 1 Snapfon ezOne Speaker Replacement, Remove the shield screws: 手順 4、 3の画像 2 Snapfon ezOne Speaker Replacement, Remove the shield screws: 手順 4、 3の画像 3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ezOne Speaker Replacement, Separate the case: 手順 5、 3の画像 1 Snapfon ezOne Speaker Replacement, Separate the case: 手順 5、 3の画像 2 Snapfon ezOne Speaker Replacement, Separate the case: 手順 5、 3の画像 3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ezOne Speaker Replacement, Remove the volume slider: 手順 6、 1の画像 1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ezOne Speaker Replacement, Remove the motherboard: 手順 7、 3の画像 1 Snapfon ezOne Speaker Replacement, Remove the motherboard: 手順 7、 3の画像 2 Snapfon ezOne Speaker Replacement, Remove the motherboard: 手順 7、 3の画像 3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ezOne Speaker Replacement, Speaker: 手順 8、 2の画像 1 Snapfon ezOne Speaker Replacement, Speaker: 手順 8、 2の画像 2
    • Remove SOS button from circuit board with tweezers.
  9. Snapfon ezOne Speaker Replacement: 手順 9、 3の画像 1 Snapfon ezOne Speaker Replacement: 手順 9、 3の画像 2 Snapfon ezOne Speaker Replacement: 手順 9、 3の画像 3
    • Pull black casing from the circuit board with fingers.
    • The black casing will not be able to be fully removed at this point
    • To fully remove the black casing, desolder the SOS button cable from the circuit board with a soldering iron.
    • The solder iron creates high temperatures that may cause bodily harm.
    • Once the black casing is removed, the speaker will now be exposed.
  10. Snapfon ezOne Speaker Replacement: 手順 10、 3の画像 1 Snapfon ezOne Speaker Replacement: 手順 10、 3の画像 2 Snapfon ezOne Speaker Replacement: 手順 10、 3の画像 3
    • With the plastic opening tools, pry off the speaker from the circuit board.
  11. Snapfon ezOne Speaker Replacement: 手順 11、 2の画像 1 Snapfon ezOne Speaker Replacement: 手順 11、 2の画像 2
    • Desolder the speaker cables from the base of the circuit board with the soldering iron.
    • The soldering iron creates high temperatures that may cause bodily harm.
    • Melt the new speaker wires to the circuit board with the soldering iron.
終わりに
作成者
4人の作成者と共同で作成されました。
John Bender
メンバー登録日: 03/26/14
818 ポイント
8のガイドは作成済み
チーム
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G5
3 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 309
