メインコンテンツにスキップ
Snapfon ez One Volume and Unlock switch replacement
必要な工具と部品
  1. Snapfon ez One Volume and Unlock switch replacement, Remove the battery cover: 手順 1、 1の画像 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Volume and Unlock switch replacement, Remove the battery: 手順 2、 1の画像 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Volume and Unlock switch replacement, Removing the plastic inserts: 手順 3、 2の画像 1 Snapfon ez One Volume and Unlock switch replacement, Removing the plastic inserts: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 手順 4、 3の画像 1 Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 手順 4、 3の画像 2 Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 手順 4、 3の画像 3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Volume and Unlock switch replacement, Separate the case: 手順 5、 3の画像 1 Snapfon ez One Volume and Unlock switch replacement, Separate the case: 手順 5、 3の画像 2 Snapfon ez One Volume and Unlock switch replacement, Separate the case: 手順 5、 3の画像 3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Volume and Unlock switch replacement, Remove the volume slider: 手順 6、 1の画像 1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 手順 7、 3の画像 1 Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 手順 7、 3の画像 2 Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 手順 7、 3の画像 3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ez One Volume and Unlock switch replacement, Volume and Unlock switch: 手順 8、 2の画像 1 Snapfon ez One Volume and Unlock switch replacement, Volume and Unlock switch: 手順 8、 2の画像 2
    • All three of these switches (shown in the red boxes in these two pictures) are removed the same way. So this guide will show the removal and repair of only one switch.
    • The button (shown in blue) should already be removed from the disassembly of the circuit board portion of this guide.
  9. Snapfon ez One Volume and Unlock switch replacement: 手順 9、 3の画像 1 Snapfon ez One Volume and Unlock switch replacement: 手順 9、 3の画像 2 Snapfon ez One Volume and Unlock switch replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to pull the volume button out of the track.
    • Pinch the two sets of clamps together and push outwards (away from the phone) in order to remove the flashlight switch (or either of the other two switches).
  10. Snapfon ez One Volume and Unlock switch replacement: 手順 10、 3の画像 1 Snapfon ez One Volume and Unlock switch replacement: 手順 10、 3の画像 2 Snapfon ez One Volume and Unlock switch replacement: 手順 10、 3の画像 3
    • To remove stickiness or dirt, clean the switch with rubbing alcohol and a brush.
    • Let dry before putting the switch back on the phone.
    • Clean the port with a towel soaked in rubbing alcohol.
    • Finally, let both the port and switch dry before reassembling.
終わりに
作成者
4人の作成者と共同で作成されました。
John Bender
メンバー登録日: 03/26/14
818 ポイント
8のガイドは作成済み
チーム
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G5
3 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 860
