はじめに
The charging port is the component of the phone that allows the charger to be connected to the phone in order to charge the internal rechargeable battery.
必要な工具と部品
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Remove the four rubber inserts from the screw holes using a pair of tweezers.
Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
Separate the front case from the back case.
Remove the metal bumper from the front case’s perimeter.
Separate the circuit board from the inside of the back case by prying between them with the opening tool.
The last picture is a view of the back of the circuit board.
Use tweezers to remove the charging port located inside the back cover of the phone.
A spudger may be needed to apply pressure with the use of the tweezers for easier removal.
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
