メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Smeg Kettle temp control jug replacement
必要な工具と部品
  1. Smeg Kettle temp control jug replacement, Opening Bottom: 手順 1、 2の画像 1 Smeg Kettle temp control jug replacement, Opening Bottom: 手順 1、 2の画像 2
    • Remove 3 Philips screws at the bottom.
    • The plastic cover should come off easily. Pry softly on the side to wiggle it out with a pry pick
    FixBotに聞いてみる
    コメントを追加
  2. Smeg Kettle temp control jug replacement, Disconnect the temp control Unit: 手順 2、 2の画像 1 Smeg Kettle temp control jug replacement, Disconnect the temp control Unit: 手順 2、 2の画像 2
    • Remove the 3 screws that that attached to the main body of the kettle (Red Circles)
    • Disconnect the heating element cables. They slide pretty easily without tools. (Green Arrows)
    FixBotに聞いてみる
    コメントを追加
  3. Smeg Kettle temp control jug replacement, Disconnect switch and LED cables: 手順 3、 3の画像 1 Smeg Kettle temp control jug replacement, Disconnect switch and LED cables: 手順 3、 3の画像 2 Smeg Kettle temp control jug replacement, Disconnect switch and LED cables: 手順 3、 3の画像 3
    • We need to disconnect the external switch mechanism from the temp sensor assembly. They are connected with a hinge (clear plastic to black plastic) in 4 points.(blue squares on image)
    • Carefully dissemble the clear plastic hinge from the temp sensor. Easy soft plastic to push away
    • With thin tweezers or a toothpick disconnect RED and Black cables from the thermal sensor. They have thin connectors so be gentle to not snap them.
    • The black one has a side gap to push the spring connector out easier. Red does too, but it is but hidden and hard to press. Bend paper clip did the trick for me
    FixBotに聞いてみる
    コメントを追加
    • The maine issue was the switch mechanism was not triggering the temp control to turn it off. some of the plastic pieces the hold the hinge mechanism has lots some integrity and it wouldn't shut off.
    • The part arrived and installed it. The kettle worked intermittently for about a month.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Sara Varela
メンバー登録日: 10/06/24
144 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 26
過去 30 日: 139
今までの合計 1,471
