メインコンテンツにスキップ
Smart Tweezers and LCR-Reader LCR-meter Battery Replacement
必要な工具と部品
  1. Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Replacing the battery in Smart Tweezers ST-5S and LCR-Reader: 手順 1、 2の画像 1 Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Replacing the battery in Smart Tweezers ST-5S and LCR-Reader: 手順 1、 2の画像 2
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Removing the PCB: 手順 2、 1の画像 1
    • Gently disconnect the tweezers from the PCB by opening the zif connection and removing the tab.
    • This will give access to the centre screw. Using a T6 torx screwdriver, remove this screw. The nut on the back of the device will fall loose; set aside.
  3. Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Removing the battery: 手順 3、 1の画像 1
    • The PCB can be removed from the housing.
    • On the bottomside, the battery connector can be disconnect.
    • Gently tug the connector away from the PCB.
    • Replace the old battery with the new one by gently pressing the connector into the socket.
  4. Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Replacing the battery: 手順 4、 1の画像 1
    • Put some double-sided tape on one side of the battery to keep it from rattling inside the device. Press the battery into the bottom housing.
    • Replace the PCB, and centre screw and nut.
    • Reconnect the tab from the arms into the zif connector
  5. Smart Tweezers and LCR-Reader LCR-meter Battery Replacement, Closing the device: 手順 5、 1の画像 1
    • When closing the device, hold the screen in the rectangle on the top housing. If the screen is not within these parameters, it may be broken or damaged while tightening the screws.
    • The easiest way to do this is holding under the screen while lining up the button's end with the bottom housing. Slide your finger out while putting the housing pieces together.
    • Replace the 4 screws in the bottom of the device.
終わりに
Be careful when closing the device. The screen must be centered in the top housing, if it is not, it may become cracked or damaged.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
brittany
メンバー登録日: 07/16/12
234 ポイント
5のガイドは作成済み
2 件のコメント
Breaking the screen is not even that bad, me, i broke the tweezers’s connector, i had to replace it with a different one.
negrea_c - 返信
Which type of connector in the battery.can you name it?
Ravinder Singh Negi - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 1,482
