メインコンテンツにスキップ
Smart Parts Ion Trigger Replacement
必要な工具と部品
  1. Smart Parts Ion Trigger Replacement, Hopper and the Air Tank: 手順 1、 3の画像 1 Smart Parts Ion Trigger Replacement, Hopper and the Air Tank: 手順 1、 3の画像 2 Smart Parts Ion Trigger Replacement, Hopper and the Air Tank: 手順 1、 3の画像 3
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Trigger Replacement: 手順 2、 2の画像 1 Smart Parts Ion Trigger Replacement: 手順 2、 2の画像 2
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Trigger Replacement, Smart Parts Ion De-Gassing: 手順 3、 1の画像 1
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Trigger Replacement: 手順 4、 1の画像 1
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Trigger Replacement, Grip: 手順 5、 1の画像 1
    • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
  6. Smart Parts Ion Trigger Replacement: 手順 6、 1の画像 1
    • Remove the grip by sliding it towards the front of the gun.
  7. Smart Parts Ion Trigger Replacement, Battery: 手順 7、 2の画像 1 Smart Parts Ion Trigger Replacement, Battery: 手順 7、 2の画像 2
    • Remove the 9V battery by unsnapping it.
  8. Smart Parts Ion Trigger Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 1 Smart Parts Ion Trigger Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 2 Smart Parts Ion Trigger Replacement, Separate Body From Grip Frame: 手順 8、 3の画像 3
    • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
  9. Smart Parts Ion Trigger Replacement: 手順 9、 2の画像 1 Smart Parts Ion Trigger Replacement: 手順 9、 2の画像 2
    • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
  10. Smart Parts Ion Trigger Replacement: 手順 10、 1の画像 1
    • Separate the gun's body from the frame by gently pulling them in opposite directions.
  11. Smart Parts Ion Trigger Replacement: 手順 11、 1の画像 1
    • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
  12. Smart Parts Ion Trigger Replacement, Trigger: 手順 12、 3の画像 1 Smart Parts Ion Trigger Replacement, Trigger: 手順 12、 3の画像 2 Smart Parts Ion Trigger Replacement, Trigger: 手順 12、 3の画像 3
    • Remove the trigger pin by tapping it out of the right side of the gun using a 3mm screwdriver.
    • Any small tool can be used for this step instead of a 3mm screwdriver
  13. Smart Parts Ion Trigger Replacement: 手順 13、 2の画像 1 Smart Parts Ion Trigger Replacement: 手順 13、 2の画像 2
    • Remove the trigger by pulling it out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Shane Villalpando
メンバー登録日: 02/02/15
1,031 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S8G42
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 2,026
