はじめに
Sometimes the Ion leaks air from the macro line after heavy use. The macro line wiggles loose causing the macro line fittings to vent air. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
Turn the gun on by pressing the power button until the red light blinks.
Turn vision mode off by pressing the power button again.
Push the metal fitting inwards and pull out the black tube. Repeat on the other side.
