はじめに
If the Ion is not shooting properly, the bolt's o-rings may need to be lubricated, or the bolt may be damaged from wear and tear. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
必要な工具と部品
Turn the gun on by pressing the power button until the red light blinks.
Turn vision mode off by pressing the power button again.
Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
3 の人々がこのガイドを完成させました。
