はじめに
This guide will demonstrate how to replace the fuse located in the cigarette lighter power source.
必要な工具と部品
Unscrew the small black screw at the base of the cigarette lighter power source.
Carefully unwind the cord at the base of the power source from the plastic case.
Remove the 15 amp fuse and replace.
Reassemble.
Where can the 15 A 12 V fuse be purchased?
5 の人々がこのガイドを完成させました。
14 件のコメント
I lost the tip that screws onto the end of the plug in and the 15 amp fuse. Can I get a replacement tip for it?
I somehow lost the tip of the plug-in, the part the screws on/off to keep the 15 Amp fuse inside.
Can I get a replacement piece or do I have to buy a new one?
Can someone please answer this??? I didn’t lose mine but the tip melted and now I can’t use my pump at all and I can’t find replacements for it anywhere:((
Can you tell me who sells the fuse for the slime air compressor. I can not find the 12V DC 15Amp fuse any where.
Were can I get a fuse for a slime air pump at
Can you tell me where I can buy the fuse 12V DC 15Amp for my slime air compressor.Ican not find it anywhere
It's just a 15 amp AGC type (glass tube) fuse. Available at your local autozone, o'reilly's, etc parts store.
My slime tire infaltor digital screen display AO and dont display the gauge properly and also it was blinking …
I have this same problem. It’s not the fuse because the unit still lights up. It has the code AO
thom -
Is it common the fuse blows be fore damage to machine is severe
Where can I get the screw on top that goes over the fuse on my slime portable inflator??
I seen this same question and no reply answer so I’m going to try. Where can I get the screw on piece that you take off and on of the cigarette lighter plug so you can replace the fuse? I have lost that end screw on tip piece somehow. Can someone please help me?
I need a fuse for a slime air pump no. Parts store. Have. Them
I need a fuse for a slime air pump no parts store have. Them. I. Been. To. Ten. Parts store. No. Haue
