メインコンテンツにスキップ
Sliding Folding Door Hinge Replacement
必要な工具と部品
  1. Sliding Folding Door Hinge Replacement, Hinge: 手順 1、 1の画像 1
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: 手順 2、 1の画像 1
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: 手順 3、 2の画像 1 Sliding Folding Door Hinge Replacement: 手順 3、 2の画像 2
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: 手順 4、 1の画像 1
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
終わりに
作成者
1人の作成者と共同作成されました。
Torianna Marasco
メンバー登録日: 03/15/21
124 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 699
