はじめに
If the device is having poor back camera performance, consider replacing the back camera of the Sky 6.0Q phone. Replacement of the backcamera of the device can be needed if the camera is not working, giving blurry or dark images, has lens damage, or if the lens is exposed to water. The design of the Sky 6.0Q phone makes accessing the back camera difficult, so it is necessary to be careful when removing the back plates and to not lose the small screws. It is recommended to use a magnetic work board to keep the screws from rolling away and are always on hand once the battery is replaced. Although removing the back camera is not hazardous, be careful of disrupting other components that could be hazardous while replacing.
必要な工具と部品
Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
Pry off the back plate with the spudger.
ある他の人がこのガイドを完成しました。
