メインコンテンツにスキップ
SkullCandy Hesh Auxiliary Cable Replacement
必要な工具と部品
  1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: 手順 1、 1の画像 1
    • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
  2. SkullCandy Hesh Auxiliary Cable Replacement: 手順 2、 1の画像 1
    • Using wire cutters, cut the auxiliary cable at the determined damaged area.
    • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
  3. SkullCandy Hesh Auxiliary Cable Replacement: 手順 3、 2の画像 1 SkullCandy Hesh Auxiliary Cable Replacement: 手順 3、 2の画像 2
    • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
  4. SkullCandy Hesh Auxiliary Cable Replacement: 手順 4、 1の画像 1
    • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
    • Twist together the same colored wires from the device cable and the new cable.
  5. SkullCandy Hesh Auxiliary Cable Replacement: 手順 5、 1の画像 1
    • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
  6. SkullCandy Hesh Auxiliary Cable Replacement: 手順 6、 1の画像 1
    • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
終わりに
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
作成者
6人の作成者と共同で作成されました。
Sarah Burk
メンバー登録日: 01/15/15
247 ポイント
3のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015人のメンバー
USFSM-STEWART-W15S1G1
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 998
