はじめに
If you device handle is detoriorated and you need to remove and/or replace it these are the steps you should follow.
必要な工具と部品
Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
