メインコンテンツにスキップ
Skil 1743-AA Corded SDS+ Hammer Drill Disassembly
必要な工具と部品
  1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly, Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 1、 1の画像 1
    • The Skil 1743-AA Cordles SDS+ Hammer Drill is an affordable tool for serious hole drilling. Note that this one had its labels removed and the cord cut off for educational purposes.
  2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 2、 3の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 2、 3の画像 2 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 2、 3の画像 3
    • Make sure the drill is not plugged in. In our case, this was easy.
    • With a Phillips size 2 screwdriver, unscrew the four 40mm screws from the front body.
    • The front comes right off. Unfortunately this part is very rigidly put together, in fact so rigidly we were not able to disassemble it any further.
  3. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 3、 1の画像 1
    • Flip over the rear body, and unscrew the 9 20mm screws.
  4. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 4、 2の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 4、 2の画像 2
    • With a pry tool, separate the two halves. You might need to go all around before they come loose.
    • Take a moment to admire all that is inside.
  5. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 5、 3の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 5、 3の画像 2 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 5、 3の画像 3
    • Unscrew the two 15mm screws that secure the cord.
    • The cord and its cradle look like one part, but actually they aren't.
  6. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 6、 2の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 6、 2の画像 2
    • Before we go any further, release the rotor from the motor assembly. Beautiful thing to behold, no?
    • You might need to lift the bearing from its position behind the motor in order to take the rotor out.
  7. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 7、 2の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 7、 2の画像 2
    • With pliers, cut the cable ties that secure the cable tree.
  8. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 8、 2の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 8、 2の画像 2
    • The complete innards should come out easily.
  9. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 9、 3の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 9、 3の画像 2 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 9、 3の画像 3
    • We are now going to take out the power cable. Its leads are attached to the trigger box.
    • With a size 3 slotted screwdriver, unscrew the two 10mm brass screws to release the power cord.
  10. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 10、 3の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 10、 3の画像 2 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 10、 3の画像 3
    • Pull apart the trigger and polarity switch boxes.
    • With your size 3 slotted screwdriver, or the pry, pry off the lid of the polarity switch. Using this switch the current to the motor is reversed to it turns the other way.
    • Interesting spring mechanism!
  11. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 11、 3の画像 1 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 11、 3の画像 2 Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 11、 3の画像 3
    • Flip over the polarity swith box. The brushes that transfer power to the motor are attached inside here.
    • The wires are not soldered which allows you to replace the brushes. Don't lose the springs that hold 'em in place though!
  12. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: 手順 12、 1の画像 1
    • You have completed the disassembly!
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Oscar Verbeek
メンバー登録日: 03/07/18
295 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 35
今までの合計 1,039
