はじめに
First decide the gear ratio you desire. 16/56 = 3.5 is most common:
Gear RatioPinionTreadWheelBeltE steps
41456std1401120
3.51656std140980
31854std140840
2.82056std140784
3.42857144848130960
3164848130840
2.4204848136672
2163232112560
Note: 48 and 32 wheel available on request. You will need to order a shorter belt as indicated.
    • There are many options for filament between type and color. You can mix and match to suit your style and needs.
    • Generally I recommend PETG as it has good all around properties. This is the same as the stock extruder. I used an all PLA version for about 9 months with little trouble however. Annealing is another option, but is challenging due to the shrink factor.
    • Certain parts have unique needs that will favor one type over the other. See part listings.
    • Some parts make look slightly different over time as new versions come out, but functionality and printing are correct as listed.
    • I use and test all parts in Slic3r PE. Print parts as oriented, do not rotate around X or Y. Using default settings unless otherwise indicated below.
    • recommend 0.15 layer, gyroid
  1. PETG or PLA PETG or PLA
    • PETG or PLA
  2. PETG or PLA
    • PETG or PLA
  3. PETG.  If you choose Fin, it requires PETG for flex. Tail - similar to Prusa style connection
    • PETG. If you choose Fin, it requires PETG for flex.
    • Tail - similar to Prusa style connection
    • Fin - more flexible, less resistant connection
    • Note that the wire rack at the end of Fin is designed to have split openings at the top even though the stl appears closed. This will resolve when you slice.
  4. PETG
    • PETG
  5. PETG
    • PETG
    • Note that this has one built-in ring support. We will remove it in a later
  6. This part is separate and small so that you can print in a high temp resistant filament. Has two small breakaway supports that should be removed.
    • This part is separate and small so that you can print in a high temp resistant filament.
    • Has two small breakaway supports that should be removed.
    • R1 version successfully printed in PETG, HTPLA, ABS, and PC.
  7. PETG or PLA
    • PETG or PLA
  8. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  9. PETG
    • PETG
  10. PLA, though PETG can work Std version: this is similar to the stock Prusa extruder, where the PTFE is cut flat and terminates before the gears
    • PLA, though PETG can work
    • Std version: this is similar to the stock Prusa extruder, where the PTFE is cut flat and terminates before the gears
    • PTFE version: this has the PTFE pass through and needs to be cut tapered to fit between the gears. This is best suited for flexible filaments.
    • Optionally print at 0.1 layer with 0.25 nozzle for extra high precision for tightest fit with Bondtech drive gears. No escape for flexible filament!
  11. PETG
    • PETG
  12. PETG
    • PETG
  13. PLA works well here.  PETG also.
    • PLA works well here. PETG also.
    • It is best to print this part by itself and not plate it with other parts. This helps ensure you get clean teeth.
    • Print either the 56 or 54 tooth version depending on the gear ratio you want.
  14. PETG, HTPLA, PC
    • PETG, HTPLA, PC
    • Print one size depending on the gear ratio you want
    • Use 3 perimeters. Turn off 'detect thin walls'
    • 14T
    • 16T
    • 18T
    • 20T
  15. PETG, maybe HTPLA
    • PETG, maybe HTPLA
    • Needs some flex, so PC is poor choice
  16. PETG
    • PETG
    • Note that this piece has two built-in supports. Do not remove the cylinder yet.
  17. I recommend printing  control knobs in a contrasting color. Any filament should work fine
    • I recommend printing control knobs in a contrasting color.
    • Any filament should work fine
    • Tensioner knob
    • PINDA knob
  18. PETG or PLA
    • PETG or PLA
    • Print a few spares, that one is easy to loose. Maybe use a brighter color
  19. PLA, though PETG can work Dark color is best.
    • Dark color is best.
    • Direct sensor cartridge for stock setup
    • Indirect sensor cartridge (additional parts necessary)
  20. PETG or PLA Standard for direct load Bowden for either reverse Bowden or MMU connection.  Requires M5 heat-set nut.
    • PETG or PLA
    • Standard for direct load
    • Bowden for either reverse Bowden or MMU connection. Requires M5 heat-set nut.
    • also M6 version for direct attach of PC4-M6 coupler
  21. PETG or PLA For use with indirect filament sensor For indirect filament sensor and Bowden connection.  Requires M5 heat-set nut
    • PETG or PLA
    • For use with indirect filament sensor
    • For indirect filament sensor and Bowden connection. Requires M5 heat-set nut
  22. PETG or PLA
    • PETG or PLA
    • Serves as both bearing axle and spring, so some give is good.
  23. PETG, 0.15 layer Add supports, build-plate-only, 40 deg threshold
    • PETG, 0.15 layer
    • Add supports, build-plate-only, 40 deg threshold
    • Use 4mm brim
    • OmegaV is for use with e3d Volcano heater block, but printed similarly.
    • You are ready to move to the next stage, Preparing Components
まとめ
4 の人々がこのガイドを完成させました。
JLTX
メンバー登録日: 2019年01月02日
635 ポイント
7のガイドは作成済み
統計データを表示:
過去 24時間: 8
過去 7 日: 55
過去 30 日: 231
今までの合計 891
