メインコンテンツにスキップ
Skateboard Wheel Replacement
必要な工具と部品
  1. Skateboard Wheel Replacement, The skate board fix up: 手順 1、 1の画像 1
    • With a 13mm wrench, remove the axle nut located in the center of the wheel.
    • Set the axle nut aside, and remove the wheel.
  2. Skateboard Wheel Replacement, Remove the Bearings: 手順 2、 1の画像 1
    • Position the wheel at the end of the axle.
    • To remove the bearings, gently pry the wheel at a downward angle.
    • Perform this prying process on both sides of the wheel.
    • A bearing spacer should fall out once the bearings are removed.
  3. Skateboard Wheel Replacement: 手順 3、 1の画像 1
    • Position the new wheel on a flat surface.
    • Press the bearing into the hole of the new wheel.
    • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
  4. Skateboard Wheel Replacement: 手順 4、 1の画像 1
    • Flip the wheel over.
    • Insert the bearing spacer into the back the wheel.
  5. Skateboard Wheel Replacement: 手順 5、 1の画像 1
    • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
    • With the bearings in place, the wheel can be placed on the axle.
  6. Skateboard Wheel Replacement: 手順 6、 1の画像 1
    • Slide one washer onto the axle.
  7. Skateboard Wheel Replacement: 手順 7、 1の画像 1
    • Slide the wheel onto the axle.
    • The axle should go through both bearings and the bearing spacer.
  8. Skateboard Wheel Replacement: 手順 8、 1の画像 1
    • Slide the second washer onto the axle on the outside of the wheel.
  9. Skateboard Wheel Replacement: 手順 9、 1の画像 1
    • Tighten the axle nut firmly.
    • Do not over tighten. The wheel should spin freely.
    • Repeat steps 1-9 for the remaining wheels.
終わりに
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
9 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Jared Stine
メンバー登録日: 10/05/12
800 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G32
5 メンバー
6のガイドは作成済み
3 件のコメント
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - 返信
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - 返信
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 54
今までの合計 78,200
