メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
1°/ Remove the 4 screws on the bottom (take care because to one, the blue screw, of them is shorter than others).
パーツ
パーツは指定されていません。
  1. 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
    • 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
  2. Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
    • Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
  3. Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
    • Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
終わりに
8 の人々がこのガイドを完成させました。
Greg
メンバー登録日: 2012年12月10日
349 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 2,608
