メインコンテンツにスキップ
Siemens-Maquet Servo-i Battery Module Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
    • Check the battery date. The battery needs replacing after 3 years.
    • The manufacturing date is listed in the format (year-week) on the battery label.
    • Servo-i User Manual page 19.
    • If battery status on touchpad display is red make sure to replace battery modules.
    • At least one battery module must be installed at all times. If not the ventilator will not work properly.
    • Store uninstalled batteries at 15-20 degrees celsius.
  1. Siemens-Maquet Servo-i Battery Module Replacement: 手順 3、 1の画像 1
    • Wait for the battery to be fully charged.
    • To check this, press the battery power symbol button on the battery.
    • All four LED's must be lit.
    • Servo-i User Manual page 20.
  2. Siemens-Maquet Servo-i Battery Module Replacement: 手順 4、 1の画像 1
    • With gas, patient tubes and test lung connected, let the Servo-i run in a ventilation mode.
    • Disconnect mains power to the unit to allow battery operation.
    • Allow ventilator to run and make sure 'No battery capacity'- alarm is not activated.
    • Servo-i Service Manual 5-2.
  3. Siemens-Maquet Servo-i Battery Module Replacement: 手順 5、 1の画像 1
    • The time between the 'Limited battery capacity'- alarm and the 'No battery capacity' alarm must not exceed 7 minutes.
    • The event log contains the records of alarm times.
  4. Siemens-Maquet Servo-i Battery Module Replacement: 手順 6、 3の画像 1 Siemens-Maquet Servo-i Battery Module Replacement: 手順 6、 3の画像 2 Siemens-Maquet Servo-i Battery Module Replacement: 手順 6、 3の画像 3
    • See if the upper part of the module is equipped with a latch. This means it is fixed and follow these instructions to disassemble a battery from the battery module.
    • 1. Locate a small hexagonal wrench or screwdriver.
    • Place the tool in the small hole on the right hand side.
    • 2. Simultaneously push the release button.
    • 3. Remove the tool, while still pressing the release button.
    • 4. Continue to keep the button pressed until the battery pops out.
    • 5. Pull out the battery module.
    • Servo-i Service Manual 4-18.
終わりに
作成者
4人の作成者と共同で作成されました。
Monroe Erle
メンバー登録日: 05/04/20
133 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S1-G2, Zimmerman Spring 2020 Cal Poly, Team S1-G2, Zimmerman Spring 2020人のメンバー
CPSU-ZIMMERMAN-S20S1G2
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 26
今までの合計 1,011
