はじめに
The gaskets of the brewing unit are heavily used and should be replaced from time to time.
The Siemens brewing unit is identical to units of other brands, e.g. Nivona, Bosch, Melitta.
必要な工具と部品
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
To reassemble your device, follow these directions in reverse order.
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
16 件のコメント
Très intéressant tutoriel.
Une heure me semble suffisant comme temps nécessaire.
À propos de « Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult », c’est justement ce joint qui semble défectueux. J’ai pu l’enlever et le remettre, mais n’en ai pas trouvé de remplacement (-:
Maybe this one. It’s from Nivona, but the brewing unit is the same:
I have problem with my brewing unit of Siemens EQ 3 S300. Can you have an instruction to open it?
