はじめに
If these microswitches on the drive do not work precisely, the machine will not work properly and the drive may be damaged. Replacing the Cherry DX41 microswitches is not very difficult.
Note: you can also open the drive without unscrewing it completely. Then skip the corresponding steps.
必要な工具と部品
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
Open the cover over the drive. It is held by latches.
Remove the cover.
The two microswitches are exposed.
Follow the the steps in reverse order to reassemble your device.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
VauWehさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
