はじめに
If the grindstones are bold, the coffeebeans are more crushed than grinded. New grindstones improve the aroma substantially.
必要な工具と部品
Remove the water container, the brew group and the drip tray with pomace container.
Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
Lift the top off.
On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
The grinder is situated on the top right rearside of the device. The adjuster and the outer ring can just be taken off, but this is only necessary if the grinder has to be completely replaced. Be careful and do not use excessive force.
The following pictures show a grinder of a Jura and there are slight differences. But since the grinder is the same, the repair is basically the same.
Now the grinder is free. Again take a picture, then pull out the axis of the adjuster with moderate force.
Depending on the model you will find a silicon sealing on top of the grinder ring, remove it.
Watch the fabrication signs , here green. This alignment must be restored later. Now turn the great black gear about 90 degrees counterclockwise. The grinder ring is free and can be lifted off.
The grinding cone is fastened with a long Torx T20 screw. The screw head is often covered with remnants of coffee beans. Expose the head and turn the screw out counterclockwise.
Now the bean feeder (the small white snail) can be removed. The grinder cone and drive can now also be lifted up carefully.
The grinder is usually filled with old, sticky coffee grounds. Clean everything carefully for an excellent coffee aroma.
Gently lift the felt ring around the drive shaft with a needle, then wipe it clean with a damp cloth. Do not attempt to wash it, as there is a risk that it will swell. When first used, turn it over with the clean side up.
Clean the inside of the grinder with a brush and damp cloth, and the blades with a dishwashing brush. Ensure it is properly dried before use.
Push both of the small latches alternately. Then the ring cover should come out.
Two clamps hold the grinder ring in its place, push them aside and it should come free.
Again clean everything. Press the new ring and cover in its place. With that the grinder ring is exchanged.
First insert the cleaned driver, then the three sleeves, springs and balls. Now fit the grinding cone on the three balls.
Then fit the auger, screw in central screws. When screwing in, push the cone downwards and make sure that everything meshes.
Insert grinding ring. The black gear is turned to the right again until the three marks are aligned. Then reinstall the adjuster drive shaft as it was originally.
Then install the remaining parts in reverse order.
You can set the grinding degree nicely by placing an empty roll of toilet paper perpendicular to the open mill and filling it with a few coffee beans. Plug in the plug (be careful!), choose a cup of coffee and watch as the coffee grounds fall out of the grinder.
These two pictures are no fake: Before repairing the grinder the coffee is thin and transparent. With new stones the coffee is strong and has a fine crema. The repair was a real success!
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
VauWehさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
