メインコンテンツにスキップ
Siemens A56 Back Plastic Cover Replacement
必要な工具と部品
  1. Siemens A56 Back Plastic Cover Replacement, Battery: 手順 1、 1の画像 1
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Back Plastic Cover Replacement: 手順 2、 1の画像 1
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 Back Plastic Cover Replacement, Front Plate: 手順 3、 3の画像 1 Siemens A56 Back Plastic Cover Replacement, Front Plate: 手順 3、 3の画像 2 Siemens A56 Back Plastic Cover Replacement, Front Plate: 手順 3、 3の画像 3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  4. Siemens A56 Back Plastic Cover Replacement, Back Plastic Cover: 手順 4、 3の画像 1 Siemens A56 Back Plastic Cover Replacement, Back Plastic Cover: 手順 4、 3の画像 2 Siemens A56 Back Plastic Cover Replacement, Back Plastic Cover: 手順 4、 3の画像 3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  5. Siemens A56 Back Plastic Cover Replacement: 手順 5、 3の画像 1 Siemens A56 Back Plastic Cover Replacement: 手順 5、 3の画像 2 Siemens A56 Back Plastic Cover Replacement: 手順 5、 3の画像 3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
終わりに
作成者
4人の作成者と共同で作成されました。
Joseph Casey
メンバー登録日: 03/26/14
409 ポイント
4のガイドは作成済み
チーム
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G6
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 253
