はじめに
Taking out the thumbwheel.
  1. Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  6. After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  7. Remove 2 screws using the Torx 6 screwdriver.
    • Remove 2 screws using the Torx 6 screwdriver.
  8. The thumbwheel and casing will be loose, gently remove it.
    • The thumbwheel and casing will be loose, gently remove it.
ゴール
michael albaum
メンバー登録日: 2010年01月20日
45 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010人のメンバー
CPSU-MANESS-W10S3G19
4 メンバー
11のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,050
